42-380 recap
I'm recapping my 42-380. Im almost done with the exception of 4. Does anyone know an easy way to get the 2 line filter condensers out of the power block? And how to get rid of all the black filling? Also there are 2 other caps that are hard to get to. One is under the board and the other is below the bias resistor and buried in wires. Anyone have any suggestions?
Have a look at this thread for how to restuff bakelite blocks:
http://philcoradio.com/phorum/showthread.php?tid=9107
There are lots of these guys in Philco radios. Once you get used to them they're not bad at all - and I find them much easier to restuff than normal cylindrical paper caps.
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
There are currently 795 online users. [Complete List]
» 3 Member(s) | 792 Guest(s)
