reduce voltage
Any way i can reduce transformer voltage to my electrolytic caps ? Maybe with a power resistor ? have 125 volts receptical current i think this is problem .
tranformer rated at 750 volts . Idont have enough understanding of a bucking tranformer . Put some 4.7uf in and 10mfd at 450 volts they blew after awhile.
Or maybe i can do it at line cord. Icon_rolleyes Icon_redface Icon_idea
Thanks humbeled Denver.
Bucking transformer or variac is best. To do it with power robbing resistors is a poor way to go. Would need to know the details of your circuit starting with the make and model.
Sorry thought i did philco model 111.
http://www.nostalgiaair.org
Try a 1000 ohm 10 watt resistor between the cathode of the 80 rectifier and the first electrolytic cap and see if this is sufficient. May need to experiment some with the resistor value.
Edited: 3/19/2010
Will do have to order some resisters . What do you think 100 to - And what size cap would be best.
Thanks alot Denver. Icon_biggrin
Your new filter capacitors should not have blown even if your line voltage is 125 volts.
Are they connected correctly?
Are you sure?
You can't be too careful, you know... Icon_smile
Pretty sure on big cap block terminals 10 and 9 for electrolytic caps to #3 negative end to #3.
THANKand thanks Denver Icon_rolleyes Icon_biggrin
Ron has a clearer schematic on this site than the one on Nostalgia Air:
http://philcoradio.com/tech/images/111.jpg
Carl
Northern Panhandle, WV
Agree with Ron saying that those caps should not have blown to begin with. Take some voltage measurements of the power supply again.
Concerning using a resistor to drop voltage. Assuming the average B+ current is approximately 80 milliamps and with a 1000 ohm resistor would drop 80 volts. Wrote earlier 100 ohms but that would only drop 8 volts which is not much. A 1000 ohm resistor would need to be 10 watts.
The resistor solution is not perfect since during warmup the voltage can still surge quite high. Rectifiers tend to warmup first before the other tubes are warm enough to start drawing current.
Thanks will do all great help. Icon_wink
Denver
Another thing to check is the negative bias going to the 45 tubes. If any of those resistors labeled 57 and 58 are open or increased dramatically it will also cause a large increase of voltage across the caps in the power supply. Resistor 59 in the cathode circuit of the 45 tubes is worth checking too. It could cause higher than normal B+. These resistors balance the loading of the power supply and should be within 20% tolerance.
Will do . can,t check voltage waiting on caps & resisters. Icon_biggrin
Denver.
WAS THINKING MAYBE A LITTLE TO MUCH . Would changing my 80 rectifier tube blow a cap . I was looking at the tubes the 80 had some blue in it so changed it thats when the
electrolytic cap blew. Or would the blue color be from to much voltage. Still havent recevied caps yet . Live in small town have to order everything Icon_mad
Thanks alot Denver Icon_rolleyes Icon_biggrin
hi I figured out why voltage running high when i checked. Wasn,t hooking speaker up Icon_redface Hard set to work on big console big speaker.
Ihave it playing fine picks up good for about 20 min . Then fades out let cool off then plays 20 min again .
I replaced every cap resistors and bad tubes . Only things i did not are the micas what do you think.
If i did which ones .
Thanks Kent. Icon_rolleyes
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
There are currently 4754 online users. [Complete List]
» 2 Member(s) | 4752 Guest(s)
