Philco 39-55 Adventure...
Hi all:
I acquired a PAIR of 39-55s (sans mystery remotes and all tubes, waah) a few months ago, which were literally waiting at the curb for the trash. Now, having read a few things about the operation and alignment/repair of these units, it seems to me a good idea to get the main radio portion functioning first, then tackle the remote receiver side. Therefore, has anyone got a 'tidy' way to operate the unit without the remote side? Could it be as easy as not installing the tubes for the remote rcvr? If so, then so much the better, as a full set of tubes is in the $100 ballpark - rather not have to buy them all at one time (not to mention 2 sets). As always, thanks in advance for all input.
Stirling KC0NXM.
Until next time,
Stirling KC0NXM.
Wow, TWO 39-55 sets? Lucky you! Icon_smile Congratulations on your acquisition.
The radio will operate without the four tubes used in the Mystery Control section of the set. However, keep in mind that you will need to replace the motor run capacitor (59), because the off-on-volume control is operated by a motor - whether you use the Mystery Control remote or not. Also replace electrolytic (66) in the stepper circuit. In fact, you should go ahead and replace all of the paper and electrolytic capacitors, including those in the Mystery Control section, as well as any off-tolerance resistors; even if you do not plan on using the Mystery Control right away. This way, you won't have to go back into the set later on.
Cap (59) is shown as a conventional electrolytic on the schematic. It isn't! It should be replaced with a non-polarized unit rated at 30 volts or better. You might find an ideal replacement, a new motor run capacitor, at a motor rewinding shop.
Two tube vendors worthy of your consideration:
http://www.findatube.com/
http://www.vacuumtubesinc.com/
Both offer used as well as new tubes, and they stand behind what they sell.
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
There are currently 2119 online users. [Complete List]
» 2 Member(s) | 2117 Guest(s)
