Philco 66 Faceplate
The bakelite dial faceplate on my Philco 66 cathedral version cabinet is missing and needs to be replaced.  Does anyone know if any of the other models use the same faceplate such as the 60, 38..?  Thanks for any help on this.
Hello. You might look at the 2 dials Radio daze has on their site. One dial shows it works for both 60 & 66 the other is a 66/ 66S/66X Don't know for sure which one you would need.
Here's the link.
http://www.radiodaze.com/dials-plastic-o...red&page=4
If by "faceplate" you mean escutcheon, then some 60 and 38 models use the same escutcheon.
Some 38/60/66 Bakelite escutcheons are small, later ones are large so you need the proper size for your radio.
That's a bit odd the dials for the 60 and 66 have different sw coverage. The 57 is a little bitty set wouldn't think it would fit at all. The three of these should have different dials unless I'm missing something. Must have the numbers mixed up.
He asked about a faceplate (escutcheon), not a dial scale. Two different animals.
Thank you all for your answers.. escutcheon is the correct word to use for it and what I need.  I think it is perhaps the smaller version but just not sure.  The screw holes in the case for it are very close to 1 3/4" center to center and the opening for it in the case is 1 1/4" high by 1 3/8" wide.  There seem to be a number of ones available for either the model 60 or 38 but very rare to see the model 66 version for sale.  Oh well.. just have to keep looking I guess.
Help with Supreme 599
This tube tester wont work to test tubes or center the needle but works on DC volts. I checked the line adjust rhehostat...daveone23 — 07:04 AM
[split] New member...
Far as I know, that plastic insulator should be mica. I don't know if plastic is an equivalent insulator.RodB — 10:51 PM
Ok, I think I'm about done.  I've got one anomaly left but other than that, it is working great and picking up lots of s...HowardWoodard — 09:34 PM
Abandoned Zenith 9-S-367 located/Galesburg IL
As I looked through Zillow I noticed an abandoned house for sale in Galesburg Illinois for $14,900. There appears to be...bridkarl — 05:42 PM
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
There are currently 530 online users. [Complete List]
» 2 Member(s) | 528 Guest(s)
