41-608 code 122
(12-29-2017, 06:55 PM)PhilcoDom Wrote:  With regards to these capacitors, what do they control?
#21: electrolytic condenser
#81: dual condenser
#21 filter power for the detector.
#81 is the MAINS filter, reduces interference coming from power. Have to be Y-rated caps. Both need to be changed but especially the latter.
Thank you, Morzh.
#21 filter power for what detector?
Thoughts on why the turntable will not spin despite motor working? Gear driven
For the 1st one.
(12-29-2017, 08:41 PM)morzh Wrote:  For the 1st one.
Thanks again, morzh. I will be replacing #21 and #81 tomorrow.
Anyone know or care to venture a guess as to why the gear driven turntable will not spin? I can hear the motor start when I turn the phonograph on.
Is the motor itself spinning?
(12-30-2017, 09:23 PM)morzh Wrote:  Is the motor itself spinning?
Appears to be. If I push up on it just slightly it will make contact with and “grind” against something. When I move the turntable clockwise, the needle arm moves. Counter clockwise it sounds like the turntable is trying to engage.
hi dom
their are 2 different types of turn tables
1 is rim driven = lift up on platter and wheel runs along outer rim  of platter
2 is more complex = platter just sits on top of spindle  under base is a gear
   its two pieces of pot metal brackets with center rubber disc
sam
Where to find replacements for the #2 problem? I've been scouring the web for something to replace that pot metal disc assembly...
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
There are currently 7416 online users. [Complete List]
» 2 Member(s) | 7414 Guest(s)
