Bakelite block condensers
Rebuilding bakelite blocks and got one (4989E) with a resistor in it.
What type/wattage resistor will suffice?
Carbon?
Wirewound?
1/4 watt?
1/2 watt?
Thanks and have a good weekend
Tim
I think the answer is "yes, any of the above". What model is the radio for further verification of how it applies in the circuit?
-Bill
Hi Exray
Model 70 (early) inside the grandfather clock (570)
My diagram escapes me (in my mess) right now.
Block has a .09mf cap and a 250 ohm resistor.
Tim
I used a 1/2 watt 250 ohm in mine . Ihad three of the boogers never could figure what the resisters suppose to do .
Icon_rolleyes
Doing some quick math, a 1/4 watt is more than ample. Screen current of 1.7ma. P=I^2 x R (.0017 x .0017) x 250. = .0007 watts.
I don't understand why its in the circuit either? Maybe it helps prevent oscillations or something?
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
There are currently 4034 online users. [Complete List]
» 1 Member(s) | 4033 Guest(s)
