Philco 37-630T only buzzes
I just got done with the recap of this radio and when I powered it up on a Variac I only get a faith buzz out of the speaker if the volume control is up most of the way.  I touched the grid caps on top of the tubes that have grid caps on top and only two make noise. The 6Q7G makes a buzz thru the speaker and the 6K7G (if amp) makes a click thru the speaker. The 6A8G (detector) and the 6K7G (rf) make no buzz at all.
I re-tested the tubes on my tester and they're good. Th rectifier and output tube do get warm and the transformer stays cool.
I'm new to troubleshooting a Radio this old - only worked on AA5's before this.  Would the next step be checking the voltages ? Or am I overlooking something simple?
Start checking continuity of the RF coils. All of them.
Update
Talked with Tucker did a few checks and found the shadowmeter wasn't plugged in, was still in the cabinet. Works swell now.
T'happens.
Hickok AC51 tube tester
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
This is what it looked like beforePlatinumblonde36 — 01:01 AM
Platinumblonde36 — 12:58 AM
Platinumblonde36 — 12:57 AM
I'm finding some strange things in my set and for the most part it's also original, so I need to start going over everyt...Platinumblonde36 — 12:55 AM
12' Philco
There are currently 4542 online users. [Complete List]
» 1 Member(s) | 4541 Guest(s)
