38-7 Tone Control
I completed my restoration of this console radio and I noticed that the 3 position Tone Control doesn't seem quite right.  In the "first" position after you turn on the radio the tone is lets say bright.  Then in the second position, there isn't any change in the tone.  Then in the third position, there is a marked difference with the tone being lower and a lot less "noisy".  Is this normal?  It seems there should be a difference between all 3 positions. Tone control is #39 in the attached schematics.
Schematics are attached.
Crist
Crist looks like the control is showing only two connections when you switch it. 1st pos. the .006 cap is in circuit. 2nd pos. no connection and 3rd pos. .008 and .03 cap in circuit. Maybe someone can explain further about why its noisy in pos 3.
The 1st position the set is off so it doesn't effect on the tone.
Position 2 looks like it would be the normal position as it doesn't have any high frequency cut .
#3 has a slight bass boost.
#4 has a lot of high rolloff.
Would check the obvious suspects if it's not working. Tone sw contracts, proper connections, and the tap on the volume isn't open.
Yup, the Tap on the volume control was open! I have a new one coming from Mark Oppat.
Thanks everybody!
Crist
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 753 online users. [Complete List]
» 2 Member(s) | 751 Guest(s)
