Zenith 9S 307
Started restoring this shutterdial Zenith starting with the chassis which has seen previous dubious repairs.
Down loaded the circuit from Nostalgia air, and can make out most component numbering, but for the two resistors in series that connect from pin 5 of the 6F6
to the negative of the first electro and transformer CT. there is no 'r' prefix, just a couple of squiggles that could be 5's.
Can anyone help here?
Hello, Looks like it's R-1=470K first one off pin 5 and R-13= 47K ohms. Hope this helps. p.s. they use M for thousands on the schematic and spell out MEGOHM for the MEG resistors.
Thanks for the info, those values make sense.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2297 online users. [Complete List]
» 3 Member(s) | 2294 Guest(s)
