47 1230 no fm
Thanks Radioroslyn ! I disconnected 15k and it measured right on. I'll try what you suggest and get back to you. Thanks again,Bill
Hi Terry, Well plugging along on this thing. I have good am and short wave,but still no fm,no noise at all. I seem to have a problem with wiring in replacement for c419. I have tried various combos according to the original schematic which many claim is wrong. Pin 6 of the 7f8 is zero voltage. It should be 150-165 volts dc. Also pin 5 is 0 volts,it should be 3.3 volts dc. Any ideas ? Thank you,Bill
Hi Bill,
Well the reason 5 has nothing is that 6 has nothing. The hv circuit is a little confusing because the band switch is used to short across the primaries of the 1st if transformer depending on whether it on am/sw or fm. Anyway I'd check the resistance of Z300 at the blue to red wires w/the band switch in the fm position. Should see a low resistance like an ohm or two. Then switch the band switch to am or sw to see if there is a high resistance there. Should still be low.
Happy troubleshooting!
Now I think I've got it!
Thanks Terry. Will do,Bill
Hi Terry,I measured 6.1 ohms on all bands.
Ok If you have 6 ohms then you should have hv on pin 6.
Would check the contacts on the bandswitch (FS 2) . Hv comes in from R300 and goes to the switch contacts. In fm the switch shorts the primary of the AM if coil (lower left coil in Z300 leaving the hv to pass thru the primary of the fm if coil (top left coil in Z300). Follow the hv from R300 up thru the switch and Z300 where it stops is your faulty part.
Terry, First thank you for your help. I really appreciate it. I will check the hi voltage path and get back to you. Thank you again,Bill
Well.. that was quick.. I measured HV going to R300 but nothing after it, so it must be in FS4. Would a bad C304 Do that ? What do you think ? Thanks,Bill
No if that was bad (shorted) then it wouldn't receive on AM.
Hi Terry, do you mean it would receive am while switched to fm ? I don't understand why there is no HV after the R300. Thanks again , Bill
No, It would receive am when the bandswitch is in the am position.
I'm thinking that it's getting lost in the bandswitch. Do you have hv on both sides of R300? I'm assuming you as if you didn't it wouldn't receive on am.
Terry, no I don't have hv on both sides of r300,but am works fine. Thank you,Bill
Ok you have it on one side?? Do you have it on both sides in am?? Is it the proper resistance (abt 50K)?? If so then measure the resistance from the top of R300 to chassis ground. Should see a high resistance maybe 25K or better.
Well I think I'm done with this nightmare. I soldered a loose wire on 7f8, and noticed increased hum. I now have no hi voltage after R100 15k resistor....again. No am,no fm, no sw. Thanks to all for your help..........Bill
Good Morning, does anyone have photos of the underside of 47 1230 ? Thank you,Bill
There are currently 2409 online users. [Complete List]
» 1 Member(s) | 2408 Guest(s)
