42-1008P 10 inch Record Start Adjustment
My unit has had the BOL swapped out as well as the motor mechanism.
It's not starting at the front of the 10 in when that flapper is flipped over. What adjusts the starting point for the arm when using 10 in records?
With the mod's that have been done is that just a loss of functionality?
The main arm gear has a movable arm that sends the unit down a different trench that was gunked up in place.
Currently working to free it up and get it to ride correctly.
Maybe I'll post a video of what I found so it all makes sense.
Ok so here is a video. Everything is still working fine it was just the cable on that 10 inch flapper that came off the pulley. Messing with it in the position I started it out with in the video causes slack and then it came off.
Also just FYI both of those records are crap and so is my needle. This is all about functionality at this point. I was not worried about harming either record or needle.
linky
Feel like I'm talking to myself but I do have a question.
In manual mode when the record is done the needle stays down and just spins on the record right?
When in automatic mode it will continue to replay a record?
This is all the correct behavior?
Usually,
In automode it will either play it again, or drop another record, if you can stack them, and play again.
hi edisla
this should help you
https://philcoandy.wordpress.com/2015/12...resources/
best place to start is to clean off old grease and lube it
I have not played with 42 bol yet
sam
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
There are currently 5298 online users. [Complete List]
» 2 Member(s) | 5296 Guest(s)
