model 84b
>are you running a polarized plug ensuring the hot is switched?
No, You can if you like not a big deal. I don't particularity like them as they don't fit into some receptacles.
> but it seems that 10mfd  50vcap from the ct to ground (28) wouldn't be too happy if you didn't,especially as the chassis must be grounded.
Well the 10 mfd doesn't care at all about the mains polarization as it is isolated thru the power transformer. It's strictly there to filter the negative dc voltage. The other part of 28 (.015) on the primary of the transformer gives the chassis a rf ground thru the neutral side of the mains. It's better to connect an earth ground (one not related to the mains ground or neutral) as the mains can carry a lot of noise.
perhaps i misunderstood,im still not used to the idea of philcos attempts at the worlds first IC! i was on the wrong side of the transformer! forgive my ignorance! by the way what are your thoughts on coating the transformer coils with polyurethane? mine all read good.
No problem! I find myself on the wrong side of a transformer every once and a while too!
Not sure what effects it may have on the efficiency (known as Q of a coil). By lowering the Q it can foul things up, Oscillators won't oscillate, poor sensitivity, and poor selectivity.
I would stick with wax, nothing, or just a bit of lacquer. I'm thinking that getting rid of the original plastic strip is a big help to alleviate the rot problem.
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1024 online users. [Complete List]
» 1 Member(s) | 1023 Guest(s)
