Triplett 3413A Tube Testers
I have a couple Triplett 3413A tube testers in need of calibration. Before I dive into this, more-or-less blindfolded, I figure I should replace their rectifiers. As described on the Triplett parts list, they are "copper oxide, 1/2 wave, two lead" rectifiers. Have never heard of copper oxide rectifiers before. Are these essentially the same as selenium rectifiers? Can they be replaced by diodes? The B+ circuitry in these testers is very primitive -- no tubes or electrolytics (the only cap in the tester is a .1 MFD 400V bypass). Any advice would be greatly appreciated!
This discussion may help:
http://antiqueradios.com/forums/viewtopi...9e1c6d3f5b
Carl
Northern Panhandle, WV
Thanks for the referral. That was me on the other forum also. I now have all the information I need to replace the copper oxide rectifiers, resistors and capacitor to perk up my 3413A's. I appreciate everyones help to a relative novice in the tube tester rebuilding business.
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
There are currently 378 online users. [Complete List]
» 2 Member(s) | 376 Guest(s)
