Philco First Audio Replacement
Hi, I am working on a Philco model 90 Cathedral radio. This has been a real work in process. I have successfully replaced the main transformer, speaker and all bad wiring. By the way, I started a thread on trying to sort out the transformer windings and I got called away to work for several days so I did not get back. I am sorry I did not close that thread. I did not mean to disrespect those that gave direction. I respect you guys a lot. I figured the transformer out and it tests perfect. The last problem I have is the first audio transformer is burned out too. I have been everywhere to try to find a used part and I am giving up. My question is, is there a new transformer out there that would work as a replacement for the first audio. This is a push pull twin 45 tube model.
https://www.tubesandmore.com/products/tr...tage-10-ma
Thank you so much Terry. I ordered it. Just for educational purposes, is it possible to teach me how to calculate that in the future. It had open windings on it because it had overheated and I couldn't ohm it out. How would I do that math to see what to order. I want to understand so bad. I feel all alone here in Indiana lol.
Thx,
Hound
I doubt it. Typically it fails from the small dia wire used on the secondary winding corroding.
I keep it simple. Primary has to be able to handle plate current from the previous tube. A quick check in the RCA tube manual sez that it's abt 5ma@250v. Transformer is good for 10ma. Plate load resistance is abt 9K which is a good match for this transformer. The grid resistance isn't particularly critical it just has to high, something around 100K is good. This transformer is a good general replacement for a lot of applications, like in early battery and AC sets.
Sometimes it boils down to availability and cost. Some sets use odd transformer setups that are unreplaceable by using common replacements that are current or from years gone by. The Philco 37 and 38-690 come to mind. These can be rewound but it comes at a price. In some instants there is a work around to use a common transformer.
Right up my alley I can explain it really badly!!!
Thank you so much for the explanation and I need the luck lol.
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1026 online users. [Complete List]
» 1 Member(s) | 1025 Guest(s)
