Philco chassis 44 Newbbie help,
New to this site, 1st post.
I am restoring a philco standup radio chassis 44 looks like tuner is am and short wave.
There are 3 rubber tires in the tuner section, the one behind the dial plate and 2 more used in tuning and fine tuning. I got 2 of them but I need the 3rd(its the inner most one farthest from the dial plate) it is totally missing so I cant get it rebuilt.
Ayone have any thoughts or help. Thanks much appricated
Rich
Hi Rich - welcome to the Phorum!
Have you seen this tech section article on rebuilding the dial drive for the 44 among others?
http://philcoradio.com/phorum/showthread.php?tid=14970
It should give you the info on the replacement part you need.
thanks this is a big help and exactly what I need
Welcome to the PHorum!
Icon_wave
My Philco 37-116 Restore
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
There are currently 395 online users. [Complete List]
» 2 Member(s) | 393 Guest(s)
