noise on radio during the day **SOLVED**
#31
Sometimes there are issues on power lines with leaking insulators that can cause noise in damp periods such as overnight dew, but that usually declines rapidly when the sun comes up... Also should give fits when rainy...
You may want to track the relation to dew point & temp...
Tom
#32
For safety I would put a ground on aa5 radio some of them have a one side of the power line grounded depending on witch way it is plugged in it might have 120 volts on it.
#33
That should have said I would not put a ground on a aa5
#34
answering the Grounding suggestion.
on my antenna, screw terminal 1 is electricaly bonded to the chassis.
the instructions say if you run a random wire like i am, the install the shorting bar from terminal 1 to terminal 2, this has been done since purchase.
the outside case is supposed to be isolated and not electrified.
but........... i did tinkier with the suggested idea.
i jumpered terminal 1 to the outside case.
noise was still present yesterday on sunny conditions but D**n!!! i sure got a boost out of some of those futher away country signals for some odd reason.
I even replaced the isolator feet with something better even though my old isolator feet were showing me that my inside chassis to exterior case had 25MG ohms,,, meaning they were ok but i i was shooting for zero, which is what i read now that i did a repair and no ground jumper installed.
The power chord is poloarized, a fuse installed, and filter caps and all other caps upgraded a while back.
I am running a Ford Motor Company 4'' x 6'' speaker inside for a second year now. its purdy darn big but fits and sounds really good, plus it is 3.5 ohms matching the orginal speaker so............ its fine.
so to the noise,,,,,,
today on 23april2018 at 10am i check the noise, there is none.
why? at this moment i am at 50degF ,,, 72% humidity and fully cloaked in cloud cover.
whats missing? that cures the issue?
the sun?
if i recall last year i was having issues but it seemed to go away on its own over a long period of time.
what changes over a long period of time would be the angle of the sun i guess.
I am starting to think that just passing my antenna over my metal roof might be the problem, but im no expert.
one expert here did tell me this might be an issue (terry), he's probably right.
#35
(04-21-2018, 09:38 AM)35Z5 Wrote:  Sometimes there are issues on power lines with leaking insulators that can cause noise in damp periods such as overnight dew, but that usually declines rapidly when the sun comes up... Also should give fits when rainy...
will check tom, and to the dew, i cant help much of that with a random wire i guess.
#36
Ah, but the Beverage may be the answer, perhaps then? I'd be right on top of that one!   Icon_smile
#37
i dont have enough "straight" or level surface land to do it the right way.
i have 1000' in length of land but no more than 200 or so feet at any given point is on the same plane.
#38
Certainly leaky insulators on the power line can cause this... The power pole holding our transformer is occasionally a problem. I know this to be true because one day, for some reason I happened to be outside with a small portable SW receiver. I could make the interference cut in and out by wobbling the guy wire. It comes and goes with damp weather, warm and cold etc, but is quite uncommon so I dont worry about it.
If your interference has a 60/ 120 Hz splashy or white noise quality, this could be the issue.
#39
ok,,
24apr2018 0743 am,,
its raining outside
no noise
no sun
zip code 24941
#40
Have you tried walking around with an AM portable, with a telescopic antenna if possible (can add directionality and can be used for attenuation of strong signals)?
(04-24-2018, 10:03 AM)Phlogiston Wrote:  Have you tried walking around with an AM portable, with a telescopic antenna if possible (can add directionality and can be used for attenuation of strong signals)?
you've lost me.... not hard to do by the way
#42
no noise again today, nearly all day cloud cover till late this eve
#43
Well, you are trying to locate the source. If you walk around with a receiver the noise should get louder as you get close to it. Also used to eliminate possible sources - unplug suspected device - noise stops, great - if not move on.
An adjustable antenna will help to attenuate if very loud/strong - Like, IT"S JUST EVERYWHERE! (it isn't).
Would anyone around you, have recently installed a solar panel set-up?
#45
brad,
no solar
Phlogiston~ thanks, i get it now.
update today, sun came up, some cloud cover but for the most part, mostly sunny.
NO NOISE!!!
we did nothing different today,,, this is very odd.
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
My Philco 37-116 Restore
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
There are currently 485 online users. [Complete List]
» 1 Member(s) | 484 Guest(s)
