Question about replacement transformer for 37-660
I have am looking for a replacement for the output transformer for this radio. I have a line matching transformer with 5 primaries: 500 ohm,1k,2k,4k,and 8k. Output is 4ohm or 8ohm, listed as 10 watts.
Radio schematic calls for 370 ohm and 330 ohm ct primary on transformer (has two 6f6's)
Will this work on this radio? If not, any suggestions on what will work for a replacement?
Bill
Just remember that those "300 ohm" DC resistance numbers on schematics have nothing to do with audio impedance values. You can forget those DC numbers for this exercise.
You should be up in the 'several K' numbers for impedance on the primary. I'd go with the 4k/8k options. It will vary if you feed a 4 vs an 8 ohm speaker. An original Philco speaker of that era will be closer to 4 rather than 8 ohms. I think they lean towards the ~ 2.6 ohms neighbourhood .
The AF xfmr behaves as a 'ratio' animal to match the tubes to the speaker at AUDIO frequencies. Just try it and see. Dunno your specific transformer but you should be able to come close to spec. Lots of leeway.
-Bill
Thank you for your help. I will try it at 4k.8k primary, l don't understand the impedance vs resistance on these transformers. It does have an original philco speaker, but not from this radio. Is the 330/370 ohm value in the schematic significant as far as the load on the audio tubes?
Bill
Hi,
No, those resistances are simply noted as a troubleshooting aid so that a repairman would know what to anticipate while troubleshooting with an ohmmeter.
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
There are currently 433 online users. [Complete List]
» 1 Member(s) | 432 Guest(s)
