Philco Hippo 46-620 Code 128
Threads: 10
City: Bloomington, IL
Anyone know where I can get a schematic for this one? Not on Nostalgia Air.
This version has the 50B5 and the 35Y4
Joe Miller
Threads: 76
City: Winter Haven, FL
I can find no reference to a 46-620 on ANY site. It's not a 46-420?
No such thing as a 46-620.
Threads: 19
City: The Motor City,Detroit MI
I have the Riders schematic for both 46-420 and 48-460 Hippo models. Neither has the 50B5. Are you sure someone didn't just stick a 50B5 into the chassis before you got the radio? Can you post a picture of the chassis?
Threads: 3
City: Chesapeake VA
Well I dunno if it should have a 50B5 or 50C5 but was common in that time period for same sets to have different tubes(of course for Philco depends on code number). If the audio output transformer is connected to pin 5 it uses a 50B5, if on pin 7 it should have 50C5.
Assuming a 46-Something, would be impossible(at least from factory) to have a 50C5 as that tube wasn't introduced till 1948.
Tom
(This post was last modified: 05-09-2018, 03:39 PM by 35Z5.)
Threads: 573
I have seen on other radios output tube swap at the factory (do not remember if it was a Philco). And swapping halves of rectifier tube is common also.
Threads: 3
City: Chesapeake VA
As easy as looking on RM, the 46-420 code 128 does indeed use 50B5 & 35Y4... No schematic though..
Except for socket & their wiring connections won't be any different than one that uses 50L6 & 35Z5.. Same tubes different package..
https://www.radiomuseum.org/r/philco_46_...e_128.html
Tom
Threads: 268
Reminds me of an old radio show called "Let Pretend"
Figure out which tube (s) it uses as Tom mentions and renumber the diagram to match.
From what I remember the big difference between the runs is the spkr
some used pm vs electrodynamic. Not a big deal.
Threads: 32
City: Wellborn Florida
Looking at the bottom of the audio output tube socket and determine which pin goes to the output transformer. If its is pin2 tube should be 50A5 if pin3 tube should be 50L6. David
Threads: 268
There's a major differences between the 50A5 and the 50L6, 50A5 is a loktal base tube the 50L6 is an octal. They use two different sockets.
Threads: 54
I have three of the Canadian versions of a 46-420, or their successor models, none of which used a 50B5 tube, however two have a XXD/14AF7 mixer oscillator, and two IF amplifier tubes, whilst the third uses a 7A8 octode converter tube and has a tuned RF amplifier stage ahead of it, and is followed by a single IF amplifier tube, I don't think that any of mine used a 35Y4, or a 50A5 but I will have to look. I thought it was some of the later versions of these that used 7 pin miniature tubes, not the earlier ones? It seems that these sets were like the 1201s, they were slapping them together with whatever parts they could get in a given week.
Threads: 3
City: Chesapeake VA
(05-09-2018, 10:26 PM)Radioroslyn Wrote: There's a major differences between the 50A5 and the 50L6, 50A5 is a loktal base tube the 50L6 is an octal. They use two different sockets.
Agreed, plus OP mentions set has 50B5 which is a miniature tube, no chance it has a 50A5 or 50L6...
Tom
Threads: 273
City: Wilsonville
State, Province, Country: OR
Joe, some photos of your set's chassis and cabinet might help folks help you.
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)?
Budget constraints for Ham ...EdHolland — 01:43 PM |
My Philco 37-116 Restore
You're doing great.
I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM |
Hope you guys are still with me.
I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM |
Hello MrFixr55,
Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM |
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor!
Ron462ron — 08:08 AM |
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM |
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope.
May be time to crack that ...jrblasde — 07:27 AM |
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM |
Hi DConnant,
The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM |
The shield is on the 6H6.
It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM |
There are currently 1024 online users. [Complete List] » 1 Member(s) | 1023 Guest(s)
