No, I didn't; I was merely stating a fact. The top dog in the 1936 line was the 680X. Fifteen tubes and true High Fidelity reception. The 116X has eleven tubes and, while it also has the Acoustic Clarifiers, it is not a true High Fidelity set in that it does not have a variable IF bandwidth control.
Nevertheless, the 116X is still a great radio and certainly should be considered a feather in rdnzl's cap for acquiring such a fine radio as his first Philco.
Threads: 28
City: Lake Stevens, WA
I received the cloth today. Here is what it looks like. I think it will look marvelous. What do you think?
[Image: https://i.imgur.com/NkFmIfM.jpg]
Threads: 424
City: Boston
Mighty Fine, a very refined look. With a console where you see a lot more fabric a quality one makes a big difference. I have some sets I have used as close to original or the original cloth, others I have created my own look.
My first set ever I used a piece of left over reddish upholstery as a table set with only a few inches across the speaker it was not bad, hey I was maybe 12, it was all I had.
Good luck with that set, it will be one you will not part with. Maybe half my radios have some "reason" they can't be traded or sold, the first of this type, given to me by family, a certain friend, as an accumulator you learn to rationalize. I hope I am no the only one.
Threads: 28
I like the quality of this cloth. It is substantial and the "weave" or whatever you call it, is quite nice.
Threads: 18
City: Mesa, AZ
That cloth will look SO much better than the c-41 cloth in that unit with the smaller, more delicate openings that your grille has to offer. A lot more of the pattern will show through.  It will look exquisite!!!
Radio Daze did very well indeed with reproducing that cloth. It looks just like original cloth...right down to the subtle stripes within the "V"s. Appears identical in your photo to the cloth John O. (Radio Grille Cloth Headquarters) used to sell.
Threads: 92
City: Clayton, NC
An excellent set for your first Philco!! The 116X remains one of my favorites!!
TOM!!
Great to "see" you here!
Threads: 71
City: Linn Creek, MO
Yes Tom, long time no see!
M R Radios C M Tubes
Threads: 573
Hey! Look who's here!
How's tricks, Tom!
Threads: 28
Dropped it off this morning for a full going through, and a redoing of the grille cloth.
We are hoping the 6A3's test OK. If not, I'll be on the hunt for them. My guy has just about everything in the house but those.
I'm excited to hear what this beauty sounds like!
In a week or two, I will find out.
Threads: 28
Two new 6A3's are on the way. Mine both tested badly. One was an original that was dead. The other a replacement that was weak. Fortunately, I found them without having to pay TOO much for them.
I'm getting excited, but... it will probably be the end of next week before it's done.
Threads: 54
If you do run into a pair of 6A3s that test poorly, and can't find a new pair for a realistic non audiophool price, then you could use a pair of adapters to use triode connected 6L6s as substitutes. The only issue may be with regard to biasing the tubes, but they will handle the voltages quite easily. Fortunately I don't think that 6A3s are to the level of stupid where the type 50s are as yet.
Threads: 28
I got a new pair for $28 each. Expensive, but not as bad as many I've seen for sale online.
Threads: 28
I picked her up just a bit ago, after being gone over completely and restored electronically, AND getting new grille cloth put on.
It sounds great. I had my guy install a 1/4" RCA jack, and I'm streaming music from my laptop via a Bluetooth receiver.
[Image: https://i.imgur.com/3x198mX.jpg?1]
[Image: https://i.imgur.com/yMEEW9i.jpg?1]
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power tr...Vlad95 — 11:40 PM |
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM |
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
Haven't thought of Burgess batteres in a while
https://www.radionostalgia.ca/lib/Images/battery/us/burgess1D.jpgi
...Vlad95 — 03:50 PM |
Measure the voltages first, just in case.morzh — 02:19 PM |
Haven't thought of Burgess batteries in a while Mr. Fixer. Boston Edison always used Burgess in their Bright Star yellow...Paul Philco322 — 02:17 PM |
Thanks Sam. I'll let you know. I can probably scare some up from the local radio club.klondike98 — 02:07 PM |
Philco 89 Code 123 Osc Coil
Hello,
I thought I would post my findings on my bad oscillator tickler coil. There were 27 turns on the outer coil b...dconant — 12:38 PM |
Thanks Morzh. So it appears I did wire it incorrectly and I have to switch the wires between pins 2 and 4.bobclausen — 09:24 AM |
No, it's not a problem, just during certain condition it could show up.
Yes, an internal tube short could do that too.
...morzh — 09:13 AM |
There are currently 941 online users. [Complete List] » 2 Member(s) | 939 Guest(s)
