Hickok 600A tube tester
OK, Have been using this for a while and all was good.. I tried to turn on tonight and nothing.. NO indication on meter for Line adjust.. I checked the switch and it was good..
Anyone know what the resistance of primary of transformer should read?
I hope the transformer didn't go belly up??
Skip
I think one of the bulbs (51) is a fuse.
There is that main bulb which is never lit and which is the fuse. Right by the switch. Check that first.
Yup Did that.. Was able to get it sort of working..I think it has something to do with the power cord..If I plug it in to different sockets I get different readings.. So will replace it first to see if that's it..
Skip
Skip,
Yes, the Hickok 600 series testers are notorious for the power cord wires inside the rubber jacket crystallizing . Use at least 16 AWG.
If you strip the old jacket off after replacing there is greater than 90% chance you will find crystallized wires. Mine were bad the entire length of the cord. Manufacturing problem  Icon_e_surprised
John
OK replaced power cord Still same problem.. Here is what i noticed..
When you set the line adjust pot to read the right filament voltage the meter reads say X When you push p7 again meter reads different say Y But filament voltage doesn't change.. So tells me it some where in the Line adjust circuit .. something is intermittent maybe the push button.. I did clean the contacts and it seems to work OK.. I will try to draw out the line adjust circuit..
Skip..
OK,, Need to know what the resistors are bin following pictures.. R1,R2 ETC.. And values.. Mine seem to not be whats on schematic some of them.
Starting with these..
[Image: https://farm2.staticflickr.com/1808/4246...5ce5_b.jpg]
[Image: https://farm2.staticflickr.com/1763/4246...22a9_b.jpg]
[Image: https://farm1.staticflickr.com/833/42465...00b9_z.jpg]
Thanks
Skip
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
There are currently 809 online users. [Complete List]
» 1 Member(s) | 808 Guest(s)
