zenith 12s568 issue
Brought home another of these beauties this weekend.
Friend of mine was clearing some radios out.
Pulled the chassis, checked tubes and replaced a few weak ones, checked cadohm resistor and looked it over.
E-caps have been replaced previously.
Powers up fine and does have audio, but no reception on any band.
Tried tweeking the alignment thru the adjustment screws on the If cans.
Noticed one of the cans had no response to adjusting either of the screws.
Seems like an open coil somewhere for sure.
What would you guys suggest I try next?
I have another of these that I did a year ago, and they are super players with great sound.
I see I will be replacing some rubber wire again on this one.
Happy 4th everyone!
murf
I'd ohm out the coils to see if you have an open somewhere like you suspect.  Also if it has crumbling rubber wire and some old paper caps those could also be causing problems, but I personally like to know if my coils are good before doing much else.
What John said.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
