zenith 9s-367 question
Hello fella's,
Have a question on a zenith 9s367 chassis that I brought home yesterday.
Upon looking it over, I noticed a .05 cap that was hanging by one end.
It is attached to pin 2 of the 6J5 detector tube and a 3 terminal strip above and to the left of the tube.
I am not seeing this cap on the schematic.
I see a C4 .0001mfd cap on the schematic.
Is there a reason that this disconnected cap was installed there?
It is not a zenith cap, so it is not original.
Was there an upgrade?
Otherwise looks like very minimal work has been done to this chassis.
murf
The schematic shows pin 2 to be connected to the chassis. Was probably used as a bypass cap for something. Would just leave it out and see if it devolves any problematic issues after service.
Now I think I've got it!
  • Thanks Terry,
  • Main issue i am seeing is it is not really motor boating , but more of a motor beating noise.
    seems to vary with volume. No reception, just noise.Murf
Will leave the cap out as suggested, but the radio is just putting out a lot of noise which varies from a beating noise to a squealing noise if I try to adjust the trimmers.
Seems like it may be an alignment problem?
Have replaced most caps so far and have check the cadohm and a bunch of resistors.
Have the other 12 tube zenith over at a friends for diagnostic and now have another zenith with strange issues.
murf
Well, upon further investigation, i found that someone had removed the bypass cap.
Found a couple extra caps added that were not on the schematic.
Fixed those items and the radio now works great.
Never know what your going to find.
Murf
There are currently 2486 online users. [Complete List]
» 1 Member(s) | 2485 Guest(s)
