Philco Model Number 40-7821
Hello,
A newbie here, hoping to get some help with a Philco from clearing out my parents' house.
It supposedly has the model number "40-7821," but I am not finding a matching number in the Philco Radio Gallery, unless I missed it. The closest seems to be the 1940 Philco Tropic Model 40-780XX, except ours would be "40-78XX," which is not listed. I am unable to find a photo online that matches our model. Please see attached photos.
Any help is appreciated.
Thank you!
chootrainmama
Hi and welcome,
Your set dates from the early 50's but it looks as though it's missing chassis for the tv. The model number would start w/two numbers (like 50 or 51) and a letter (T) and three or four more numbers.
Hi GL,
Thank you for your reply. So it sounds like the operating instructions in the set don't match the Philco we found them in...
I just ran across the page at https://www.philcoradio.com/phorum/showt...?tid=14943, which looks like it will be helpful. I will use that to try to get more info the next time we're at the storage unit.
Is the photo below what you are calling the "chassis"? Does it help with ID at all?
Thanks again,
chootrainmama
Oh good you have the chassis!
The model # is probably stamped on to the chassis back edge, pic is a side view. Most of the info that Ron posted in the post you sited is for radios. I don't think there is much if any tv/combo in the Gallery. Just radios.
Is GL now your moniker or is it Good Luck? Icon_smile
The latter my friend.
Welcome to the Phorum!
Icon_wave
Thank you for the welcomes and for the tactful correction re: "GL" (sorry; I should've figured that out).
Here is an update, two photos of the back of the chassis. I'm not seeing what I might interpret as a model number from the early 50s, so I still need help, please.
Thanks again,
chootrainmama
I think I've got it pinned down [Image: https://i.pinimg.com/originals/57/14/4d/...bef483.jpg] It's a model 50T1479. Sam's 128-11.
THAT'S IT!!! Amazing, Terry, thank you! Just when I was ready to call it quits ("Phooey!") you came up with the exact match, except prettier. How did you do it?
Does it make sense to put it up on the "For Sale or Trade" part of the site? It will require some re-assembly, of course, and goodness knows what needs replacing to make it work. Alternatively, we'd be happy to donate it to a museum or charitable organization. We're pretty eager to find a new home for it, because it is taking up a lot of space in the storage unit we are trying to clear out. Any ideas are appreciated...
Thank you!
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 991 online users. [Complete List]
» 2 Member(s) | 989 Guest(s)
