Philco 70 missing capacitor question
My radio (Philco 70) does not have this capacitor, it was not used on all models. What does it do? Should I add it? I wonder if it was originally used on all chassis, and then removed or not used and then added. Thanks.
This capacitor supposedly phase-shifts the ripple 90 deg through it that when met with the ripple remaining after the choke, which is phase shifted the opposite way also 90 deg, they, being 180 degrees nullify each other.
The experience showed this is not super effective, so the cap could be taken out and the 38 cap could be increase without ill effects and with better filtering result.
Thank you for the information.
It would seem that a lot of early AC sets had these caps across the filter choke, or one of the filter chokes, maybe with the smaller value paper filter caps they made more of a difference then they did when the 1931 sets rolled around with larger value electrolytics?
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 4513 online users. [Complete List]
» 3 Member(s) | 4510 Guest(s)
