Philco 89L-troubles
>Will this work??
One way to find out. Don't think it will be an issue.
Ok.. Guess if it doesn't work correctly I can then try to find something that will..
Thanks Terry..
Skip..
There's only a couple of things it might effect if in is too high. One would be the avc voltage/timing but since it's Am we are receiving it's going to be pretty negotiable. Would raise the gain of the 1st audio state. Again not a big deal. And may not track well ( all the control at one end of the turning radius). Other than that your home free!
Ok all wired up now.. Power on tomorrow.. Wish me luck..
Skip
I'm pretty sure the vol ctl will work. Your AVC will shift. Might be nothing. If it affects things in a noticeable way, the vol ctl could be bypassed with a resistor so the paralleled result would be the same as initial value.
Ok Philco 89 Problems... Here we go again..
Completed wiring. Brought up slowly on Variac.. at 115 Volts about 400 Ma.. .. All Tubes light up..
But NO SOUND.. Not even a Hum.. Checked B+ voltage 366 Volts.. On pin 2 of output tube ( Plate) 337 Volts..
I did have the OSC and Det coils rewound.. Tubes check good.. The Field coil and output Transformer check good.
Help... What next to try?
Skip
Skip, could be as simple as a miss wire some where. I would go ahead and retrace the circuit wiring first.
So whatdoyougot on pin 5 of the 42? Should be at ground (0v) and pin 4? Should be abt -20vdc. Oh and pin 3 abt the same as pin 2. Is heater in the 42 working?
Skip, if you touch the center terminal of the volume control with your finger, do you hear a loud hum in the speaker?
M R Radios   C M Tubes
Will check all..
Thanks
Skip
Ok , Here are the results.. If CTR of volume control touched  NO sound ..
So I tried this.. I took out all the tubes and put them back in.. Now radio works.. Still almost NO noise but when I attached antenna the stations came in.. Needs alignment..  as not many stations at low end of band.. The volume control is flaky.. When you start to turn it up its gets loader until about 1/2 way then any farther the volume goes down and distorts.. See previous posts about control..
My guess is that I had a tube in wrong place..or maybe wasn't making good contact..
So now on the alignment and to see what I can do with the Volume control.. Anyone have alignment instructions?
Skip
Should be in rider's but check the code # to get the proper info.
> The volume control is flaky.. When you start to turn it up its gets louder until about 1/2 way then any farther the volume goes down and distorts.
Check your -voltage on pin 4 of the 42. If it's 0 you've got the ct of the power transformer grounded thru the -side of the filter cap.
Try another 75 tube.
Terry, OK I will check..
Skip
OK Pin 4 of 42 tube Reading -13.5 volts to ground..
Do not have another 75 or 42 tube I think.. But will look..
Skip
Have a 75 tube But no 42 Tube..
Skip
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
@ Joseph, get off the porch and run with the dogs. You fixed one, grab another. @ Morzh, I think that we are the same ...MrFixr55 — 08:59 PM
Wow! Now that is something! I’ve never seen a Philco like that, but it’s pretty mid-century.jrblasde — 06:40 PM
