Neutrowound Replacement Caps/Shields
https://www.russoldradios.com/blog
In between smoke, fires, heat and a million other projects - -
Making replacement caps for a 1926 Neutrowound receiver.
Russ
Another impossible job made possible.
Icon_clap Icon_clap Icon_clap
Looks exactly like the original...super work!
Very impressive Russ Icon_thumbup
Copy of post on WOOF Forum - - -
"After" picture added.
How thick? Well, that will vary a little and trimming of the flashing will cause a bit of variation at the base. I was aiming for a match to the original and without a micrometer measurement, they appear to be similar in thickness and strength ( I just inserted them into the radio and one was tight). The nickel could make them thicker (and of course does) but there is no reason to plate on so much nickel that fit is a problem.
The copper solution is acid-copper (basically a PH negative solution of copper sulfate).
Russ
Most impressive, Russ!
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2279 online users. [Complete List]
» 3 Member(s) | 2276 Guest(s)
