Early 20 at our local swap meet
Ok so what is so special about it?
3 people were going on about the difference from the later 20 console.
It ended up selling for around $200.00.
Nice! Makes me want to tackle my 95 Lowboy! Icon_thumbup
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
This is as much a 20 as I am Frank Sinatra.
Isn't that the 87 from Quakertown we saw here another day?
^ What Mike said. That isn't a 20, it's an 87.
Weird.....
I swear he said it was an early 20.....
He said something about the extra transformers?
Too leggy for me either way Icon_lol
Icon_smile
This type chassis with its very characteristic look was used in those radios that came before 20, including their first superhet, the 111/112.
The 20 had smaller chassis that was the first Baby-grand and would fit in a cathedral tabletop. The previous one would not; the only tabletop it would fit into was a 511.
Let alone the fact that the dial in all of these was the rotating cylinder with the surface facing the operator and so the numbers moved up-down, while in the 20 it was a circular sector type and the numbers moved left-right.
Another tell-tell sign also is the tube shield.
And, of course, the face with the knobs widely spaced in the 85 and such, vs the small triangle in the 20.
If someone paid $200 for that model 87 they obviously didn't get out much, they should have gone for a highboy cabinet version at least.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
