Replace IF transformer caps?
Hi all, I'm restoring a Philco 40-155T slant front and it's coming along great. Got her all re-capped and a re-coned speaker is on the way. This radio sounds really nice, really powerful and I have a good cabinet.
I'm questioning if, since I'm into it now, I should replace the caps in the transformer cans. The radio plays awesome, and it's some trouble to pull the cans, and I always hate doing surgery around coils. But maybe I should just do it rather than wonder later. What d'ya think?
Alan
No, the caps inside caps are usually micas and should be left alone unless explicitly failed.
Goes for all mica caps.
Unless they are post war K-tran or Automatic style IF cans, the mini If cans used in millions of AC/DC sets from the late 1940s onward, leave them alone, Philco used either molder micas or ceramic caps in these sets I think, except for a large one used on the pushbutton banks.
The one on the P.B bank does go bad so I would change it, it looks like a sandwich with no case on it. One item to check though is the audio output transformer, the primaries on those often fail in these sets.
Thanks guys, just the answers I needed, didn't want to go there. Thought maybe I would be heading off the dreaded silver mica disease.
Alan
Silver mica disease ails a specific type of caps, the open kind, not the overmolded laded type. At least not as badly.
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 1022 online users. [Complete List]
» 1 Member(s) | 1021 Guest(s)
