40-200 Push Buttons
Hi All,
I've just finished restoring a Philco 40-200 and did the alignment and is working great.
Now I'm trying to adjust the push buttons and buttons 1-4 won't adjust below 1200 KHz.
The upper buttons (5-8) work well, I adjusted them 1050-1400 KHz.
Thanks
Denis R.
Depends. We need to figure out which isn't tuning properly. Use a counter or another receiver to track the local oscillator frequency and see if it's tuning low enough ( it should be 455kc above the in coming signal . To receive a signal @ 560kc the osc should be running @ 1015kc). If that isn't working properly check 23 and 24 for correct tolerance. This is assuming that the switching and wiring is as it should be.
Now I think I've got it!
Hi Terry, I checked the wiring, switches and coils and all is well. Each coil is about 3.1 ohms.
Cap #24 = 181.0 pF
Cap #23 = 190.2 pF
I think both caps should be 370 pF, my schematic is not that great and hard to read.
Denis R.
For a better schematic go to http://www.audiophool.com/Philco.html  Scroll down to 1940 and click on 40-195/40-200.
I'd replace those to caps w/ 370mmfd. Not have enough capacity there more than likely would be the cause of the lack of the low frequency oscillator coverage. Come to think of it my 41-300 buttons won't tune below abt 700kc. Can't get down to the Grand Ole Opry on WSM out of Nashville Tenn.@ 650. I should have a look at mine.
We are Hams we can fix anything!!!   [Image: http://philcoradio.com/phorum/images/smi...wisted.gif]
de N3GTE
Hi Terry,
I replaced both caps with 370 pF caps and now I'm am able to tune through the whole BC band.
Thanks a lot for your help.
Denis R.
is this a safe plugin to download in order to get the document you posted Terry?
>>>>>>>>LizardTech DjVu browser plug-in
also,,, never seen a skinny domino cap like the one top center of your underside of the chassis!
Been using it for yrs and haven't had an issue.
I don't know how the pushbuttons are designed in the 40-200, but in some sets it's quite normal for there to be a range for each pushbutton,
so the lower ones won't tune in anything above a certain frequency, whilst the upper ones won't tune bellow a certain frequency. These are the banks that have an oscillator coil for each button, with a slug, and a trimmer, and they are electrically switched in and out of the front end. Some Philcos don't use this setup, they switch in a trimmer, and or a padder for each button rather then a coil, in which case each button should work across the dial.
There are currently 1544 online users. [Complete List]
» 1 Member(s) | 1543 Guest(s)
