Model 80 audio transformer
I'm rebuilding a Model 80 (Philco Junior). The primary of the audio transformer measures ~4.4k; the schematic calls for 364 ohms. Obviously needs replacement.
I have a same physical size scrap transformer with a primary resistance of 210 ohms.
Can this transformer be used safely as a substitute? Should I expect lower power output? The output tube is a 42.
Thanks, Don
Resistance is meaningless in this situation. What you need to know this the impedance of the pri and secondary. What you are looking for is one that has a 7000 ohm to 2 ohm (impedance not dc resistance). In reality a transformer that will match a 2A5, 6AQ5, 6BQ5,6K6, 6F6, 6L6, 6V6, 41, 42, 47, 6005 ect.. to a 4 ohm spkr is fine. Most of the aa5 transformer are kinda low in impedance (abt 1.5K)
Thanks, Terry. My substitute transformer came from a 50L6 circuit and should work per your comments.
Don
Quote Radioroslyn: "In reality a transformer that will match a 2A5, 6AQ5, 6BQ5,6K6, 6F6, 6L6, 6V6, 41, 42, 47, 6005 ect.. to a 4 ohm spkr is fine."
 An output transformer for a #41 or a 6K6 is not a very good match for a #42, the plate load impedance is different, but one intended for the others should work, including one for a 50L6, though it may be too small in other ratings.
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
