Model 80 audio transformer
I'm rebuilding a Model 80 (Philco Junior). The primary of the audio transformer measures ~4.4k; the schematic calls for 364 ohms. Obviously needs replacement.
I have a same physical size scrap transformer with a primary resistance of 210 ohms.
Can this transformer be used safely as a substitute? Should I expect lower power output? The output tube is a 42.
Thanks, Don
Resistance is meaningless in this situation. What you need to know this the impedance of the pri and secondary. What you are looking for is one that has a 7000 ohm to 2 ohm (impedance not dc resistance). In reality a transformer that will match a 2A5, 6AQ5, 6BQ5,6K6, 6F6, 6L6, 6V6, 41, 42, 47, 6005 ect.. to a 4 ohm spkr is fine. Most of the aa5 transformer are kinda low in impedance (abt 1.5K)
Thanks, Terry. My substitute transformer came from a 50L6 circuit and should work per your comments.
Don
Quote Radioroslyn: "In reality a transformer that will match a 2A5, 6AQ5, 6BQ5,6K6, 6F6, 6L6, 6V6, 41, 42, 47, 6005 ect.. to a 4 ohm spkr is fine."
 An output transformer for a #41 or a 6K6 is not a very good match for a #42, the plate load impedance is different, but one intended for the others should work, including one for a 50L6, though it may be too small in other ratings.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
