philco 16B
Thanks for the info Mike, old posts above (posts #2 and 3, page 1, this thread) edited to reflect this fact.
Good. I actually went to check it in my 2-year old thread about my 16 to make sure before I posted here.
Stall-U-Rated reports that Lasco #32 and #60 O-rings (Ace Hardware) also work in the Philco 16 dial drive mechanism.
Buy assortment KIT from Harbor freight,,,,Metric or standard sizes,,,,Cheap they are
OK so now I am confused. But what's new. I have not yet done the o-ring replacement on a model 16. This is somewhere in my future I suspect.
Am I understanding correctly that along with the Danco o-rings that I already purchased I will need another round gasket for behind the dial?
        Henry
Rogers Majestic R-646
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
