RCA V-210 field coil removal
Threads: 25
City: Lebanon
Thanks, EdHolland. I found an old 5lb spool of non ROHS 34AWG magnet wire here at work and we have an old winding machine that is used for prototyping which I can use. I just have to design a mandrel to mount and hold the bobbin.
I measured and calculated the voice coil gap to be about 0.040" and the diameter is 1", so to center the pole piece when pressing it back in I need to find a circular tube of that thickness and outer diameter. It can be metal, plastic, FR4 or even cardboard as long as it centers the pole piece and doesn't move as I press it it. We have a number of FR4 tubes that we use for bobbins and HV insulators here at work so I will have to search through them and hopefully I'll find a suitable one or one that I can machine to the proper dimensions.
Steve D
Threads: 112
City: Medford OR (OR what?)
One of the biggest issues with rewinding is supporting the coil-form cheeks. So wen you build your mandrel, try to add some large washers to keep the wire from making the coil "fat".
Threads: 25
City: Lebanon
You are right, Phlogiston, I removed all the winding wire from my coil and the bobbin is intact but very fragile. The cheeks are thin cardboard and will deform when winding. My next task it to design a mandrill and cheek support.
I want the coil to appear original and if the sides are too flimsy I'll make new ones from a different material and cover them with the old cardboard ones. Some experimenting to do.
Steve D
Threads: 291
City: Wilsonville
State, Province, Country: OR
Nice work! More than I would take on but you might save this one!
Threads: 25
City: Lebanon
So I finally got some time to work on the field coil this past weekend. I made a new bobbin from some 0.030" FR4 sheet and 1.25"OD, 0.062" wall thickness FR4 tube.
Cutting the bobbin cheeks with a fly cutter:
Pieces ready for assembly:
Next I epoxied the cheeks to the tube (original bobbin shown for reference):
Lastly I painted the bobbin flat black to match the original:
Threads: 25
City: Lebanon
Another shot of the new bobbin:
The next step is to make a setup to allow unspooling of the wire while maintaining tension and a method to guide the wire across the bobbin.
Steve D
Threads: 25
City: Lebanon
Continued from the previous post:
Finished coil:
The coil fits the pole piece and speaker frame perfectly, so the next step is to press the pole piece back into the frame while maintaining a uniform .032” voice coil gap.
After I wound this coil, out of curiosity, I re-glued the FR4 bobbin with JB weld and using the side supports wound another coil. It also wound perfectly, so now I have a spare coil or a nice inductor for any filtering needs.
Steve D
Threads: 25
City: Lebanon
Finishing up the speaker:
I made the centering collar from four strips of 0.010 Teflon material which is what I had on hand and cut each piece successively longer to maintain the same length when wrapped around the pole piece. This resulted in a thickness of nominally 0.040 and the gap appears to actually be closer to 0.038” and when compressed into the slot, fit nice and evenly tight all around.
With this arrangement I was able to easily press the pole piece back in and the resultant gap was beautifully uniform:
Next I used small strips of .007” paper to center the voice coil while I screwed the spider assembly in and glued the edges of the cone. I had to remove the cone center cap to access the voice coil to insert the centering strips:
Continued in next post.
Steve D
Threads: 25
City: Lebanon
Lastly, I glued the cone center cap back on and made all the electrical connections:
Now I just have to finish refurbishing the chassis to power it up. Hopefully it will play clearly.
This was a lot of work and a good experience and I’m glad I saw it through, but next time perhaps I’ll try harder to find a replacement speaker.
Steve D
Great job!
Laborious process too.
Threads: 38
City: Brandon, SD
I had a replacement speaker the whole time, just never heard from you again....
Threads: 25
City: Lebanon
Success, I got the chassis working and the speaker sounds great; loud and clear with no rattling, rubbing or distortion. The field coil drops the correct voltage and I Just need to do an alignment and refurb the turntable and cabinet. This was an enjoyable but laborious process which was worthwhile as I gained experience in speaker design but I probably would only do it again for a speaker that is unobtainum.
Steve D
| Hello Everyone,
