Philco 32-8248 power transformer
I have a Philco 32-8248 power transformer I need help with. The wire colors are 2- black 2-red  2- white  2-yellow  2-blue  1- green   1- brown  I checked them got ohm results but not sure what Phico colors represent for power, filament,etc?
Hello. Here is a schematic that I believe has the transformer you asked about in it with the color code of the wiring.
http://www.nostalgiaair.org/pagesbymodel...013586.pdf
Thank you so much. I am scratch building a stereo tube amp and possibly going to use the power transformer and 6v6 outputs should be fun!!
Why use the Philco transformer? The part is not that large and was made for a mono output amp, it might be borderline for a stereo where the consumption rises almost twice as the output gets the lion share of the power consumed.
Unless you are building two monoblocks, but then you need two.
Not sure if I’m going to use it. I have 40-50 transformers so the picking is good. I like building things from scratch! Icon_angel
Well, if you are building one of those 1.5W / channel class A amps for quiet private listening..... don't forget, even if you don't overload your transformer, you still want it to handle peaks adequately, and for this you need size.
Hello,
I just found this thread and am curious if you still have this power transformer?   It is the exact transformer I am needing for my Philco 46-1226.   If it is still available, would you be willing to sell it?  Thanks!
~Jon~
I am going to sell it soon but there is one on eBay now if you dont want to wait.
And so does a barber shop quartet. mmmmmmRodB — 03:54 PM
Shadow Meter Bulb
I did try an LED bulb in place of the original but wasn't impressed with the amount of light on the dial. Seems like it ...RodB — 03:51 PM
Tim Would mounting he transformer vertically change the hum, if used without additional parts? Also, in these amps...morzh — 02:25 PM
Shadow Meter Bulb
Gary I doubt it would introduce any noise. We use similar lamps for the panel indication, 12V AC lamps: they are LEDs...morzh — 02:15 PM
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
There are currently 7185 online users. [Complete List]
» 1 Member(s) | 7184 Guest(s)
