Philco Model 90 Tuning Dial
Hello friends. I just restored a Philco model 90. Turned out great. As with many of these, the tuning knob/dial slips when tuning. It turns but the dial does not. does anybody have any suggestions on how to fix this tuning bushing or where to obtain a new one?  Thank you.
Jon
Hi Jon and welcome,
Would have replied sooner  but it's been along time since I've serviced a model 90. So what's the problem? Is the tuning shaft pinching the inside of the dial hub correctly?? Is the tuning shaft worn badly so pinching mechanism can't grip the hub. Spring weak?
Hi Terry . Sorry for the late reply. The radio is put back together. I can tune the radio if I push down on the tuning knob as I turn the tuning knob. I have two model 90's with the same problem. One is worse than the other however. It is irritating indeed. The restore turned out excellent however. Could you send me a private message so I can send you my contact information?
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
There are currently 1016 online users. [Complete List]
» 1 Member(s) | 1015 Guest(s)
