46-480 Burned Resistor
I have a 46-480 radio that I have been working on for a while. When I got the radio, it did not work and I found a burned up resistor. In the Philco service manual it is R308 and R17 in the schematic published by Rider. The value is 1K and it looked like a 1/4 watt size. It was replaced with a 1 watt resistor. The radio was completely recapped and the tubes tested. I can tune in AM stations but the resistor gets very hot and starts to smell after a minute or 2. The radio also motorboats if I turn the volume up too high.
Any thoughts on what could be causing the resistor to continue to burn up?
Thanks in advance for any advice.
The obvious suspect would be C37 but the radio has be recapped. Try pulling the 7H7 tube. If no help then have to suspect a problem inside the IF transformer can next. One of those internal caps inside the IF can may have failed. Richard
Agree with all. If the tube tests good, there could be a short somewhere in the wiring between the burning resistor and the plate, either in the IF Can or around the tube socket.
Thanks for the suggestions. You got me on the right track. I replaced C37 again and still no luck. Next I pulled both the 7H7 tubes and still the resistor heated up. After the 6H6 was pulled, the problem stopped. Even though the 6H6tested good, I replaced it with a new one. No luck. I have checked the wiring and the socket and haven't found any shorts. Next I will go after the IF can T6. That has to be the problem.
Can anyone suggest a source if I need a replacement?
Thanks for the help!! - Jim
Inside the IF can there is a cap that connects the primary and secondary center-tapped windings of T6. This may have failed. Schematic is blurry but think it is marked 100 below it. May be easy to replace this cap once inside. The "100' likely indicates 100 pF. Best to use a silver mica cap here. Richard
Indeed, the capacitor in the IF can was shorted. Replaced it and it worked. Thanks to all for the advice!!!
Jim
Glad we were able to help. Congrats!
Philco 91 Speaker Replacement
I can't remember, but there was a particular product for loosening glue on the more modern "spiders", used pos...MrFixr55 — 09:43 PM
The spider is glued on the cone and so is the voice coil. I think you can use a cotton swab dipped in acetone and carefu...RodB — 02:42 PM
Restoring Philco 37-604C
Yes I saw that. If I knew, I'd probably try to arrange for getting it myself. But I have just got one. Which does not m...morzh — 01:44 PM
Philco 38-2 Automatic Tuning
When you push the lever, you are supposed to rotate the disk to the desired station. Then the magnetic tuning will acqu...morzh — 01:42 PM
I figure out the muting from another picture that helped. Now I need to know how the automatic tuning works. When I push...dconant — 12:11 PM
How would I go about removing the spider from the cone?dconant — 12:04 PM
Hello, I am having trouble getting my automatic tuning to stay unmuted. If I play with the tuning handle I can get it to...dconant — 10:51 AM
Does anyone make photofinish replacements?
Here’s the link to the DIY photofinish section of our site: klondike98 — 09:46 AM
Delco car radio Peko vibrator converstion issues
Hi Richard, Thx for posting the schematic.  As I remember as a kid, these were great performers for the time, likely...MrFixr55 — 08:56 AM
hello mr Fixr, The Electro  Powersupply that I am powering the radio with has a huge choke plus a 10,000ufd electrolyti...radiorich — 10:58 PM
There are currently 1957 online users. [Complete List]
» 2 Member(s) | 1955 Guest(s)
