Philco 16 Code 121 Control Grid Voltages?
I am working on a Philco Model 16 that has been butchered by a previous repairman. The schematic is difficult to read. What are the resistances of Resistor 81? The best I can read is from left to right, 20, 100, and 130.
Also, are the Control Grid voltages correct for the Output tubes ( two 24's ) 34 volts, the Driver tube ( 24 ) 0.6 volt and the 1st A.F tube ( 77 ) 0.4 volts?
Thank you,
nv3g
Oscar
Which version 16 are you working on, Oscar? Code 121, 122 or 123 (5-band), or Code 125, 126 or 127 (4-band)?
Sorry. I am working on a Philco Model 16 Code 121. I would expect the bias voltages on the control grids to be negative voltages. I am measuring the voltages from the control grids to chassis ground. The schematic was a little fuzzy and hard to read. I was trying to confirm if I had the resistor 81 resistances correct and if the voltages in the voltage chart were correct.
Thanks for your help.
nv3g
Oscar
Looks like #81 is a 250 ohm resistor with two taps. The first at 20 ohms(from ground) and the second at 120 ohms.
Thank you, Terry. That is what I thought trying to read a blurry schematic. I wonder about the control grid voltages, which are positive in the voltage table. I thought they were negative coming from the negative power supply source. I am looking at the voltage table ( tube socket data ) on the schematic page.
Appreciate the input.
Best Wishes
nv3g
Oscar
The control grid voltages are negative. I am reconstructing the negative bias circuit in the Philco 16 Model 121 radio.
The previous repair person tried to do a make shift repair rather than do it correctly.
nv3g
Oscar
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
There are currently 5249 online users. [Complete List]
» 4 Member(s) | 5245 Guest(s)
AvatarAvatarAvatarAvatar
