crosley barn radio
Sure reminds me of a barn or a chicken coupe with all the red  Icon_lol . Not sure to leave it alone or refinish it but that god awful grill cloth has to go.
all the coils and transformers check out including the speaker it needs the usual caps and resistors changed. According to the radio shop labels on the tubes the set is from St louis MO.
For your viewing pleasure.
Ha! I knew there was more than one red radio...
In the mid 70's I picked up a Malone-Lemon sloping panel Neutrodyne battery set. Painted this Chinese red over the entire exterior, the panel knobs, escuteon, except to a 10" rectangle across the top lid. That, must have been where the speaker sat...
The cabinet was solid walnut so it was a good candidate for strip and refinish. So it was, in ebony water stain and cabinet rubbing varnish. Knobs and panel were Bakelite so they were impervious to methylene chloride stripper. Chassis only needed a cold solder joint, repaired and worked like a dream I still have the radio...
So Jake give the stripper a try, with any luck the old finish is still under the red paint and the red should release clean from cabinet.
Chas
Pliny the younger
Just call it The Electric Chicken Coupe
" . . . god awful grill cloth, . . . "
Not that bad.
it is soaking in savogran semi gel stripper but it is really on there im having to use a scraper because there is 2-3 layers of paint.
I guess that's where the 124 chassis you're working on came from?  At least it has all three original knobs....
Yes this is it i believe it has seen a lot of use most of the resistors have been changed all of the old caps are replacements and most of the tubes are borderline weak. The cabinet is coming along ordinary paint stripper wouldn't touch the paint so i had to use acetone and over cleaner sure it is harsh but the paint cornered me.
Well the red is gone, the finish underneath is the original lacquer. That should come off with lacquer thinner. Again, put the radio in a seal-able container and forget it for few hours. Tighter the seal the better.
Avoid the scrapper. Edges of the scrapper will compress the wood, when the stain is applied these compressed wood fibers will not be as dark. If that happens the cabinet will have to be thoroughly sanded to get to fresh meat... Veneer may not hold up!
Chas
Pliny the younger
Looking GoooooD!
The grill cloth might look pretty good with the cabinet at it's original color.  Think about it before you throw it out.
I plan to use dark walnut stain to help hide imperfections in the wood.
That light color grill cloth may just be the color contrast to set off the dark walnut.  Give it a try.
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
