10 mfd in place of a 6
is that too much? i would use a 8 if i could find one in my stock.
Ur fine.
I'm just trying to be careful my mentor from years ago always told me never go to high in capacitance when replacing electrolytics.
It is possible to raise the B+ in doing this, though generally not a problem. The other issue might be exceeding the rating on the rectifier for a first filter cap such as 10uf for an 80. In this case I would not anticipate any problems.
Depends where. If it's the first filter cap, the B+ will go up, though as Russ said it is not necessarily a problem. The second cap (usually after the field coil) it is not critical at all, wthin reason - the more the better (they probably would use more but at the time larger values were not as widely available).
Well since i read the schematic wrong and this is a 25-40 cycle not the 60 set the first cap is a 10 mfd and the audio is a 6 mfd. So a 10 will be fine.
Jake, your radio is “now” a 60 cycle set. Having said that, 10 uf will still be fine.
M R Radios   C M Tubes
...by that, Steve means that your 50-A will now be operating on 60 cycle (60 Hz) AC. So don't stress it. Icon_smile
Sounds good i hope it likes a pair of 10/10 @ 450
Wow,,long time ,,,RON,,,,soo glad you are still watching all us Kids,,,,,Hope you feel some--what better ,,My Friend
Need Help to ID this radio 11 tube Philco
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
There are currently 720 online users. [Complete List]
» 1 Member(s) | 719 Guest(s)
