42-380 First timer with a few questions
Question 1
I only have 7 of these.... should there be 9 and what are they called and where does one find one?[attachment=1]
Question 2
I bought the whole capacitor set from Radio Daze and am attempting to decipher the schematic. The 2 main capacitors that come off the transformer seem to be labeled as both 20, 20A or 61 Can someone help me with this? Do I replace the 2 wire cap with 2 separate new caps? I am a little confused as to the process. If someone created a list of which part # is replaced with which new cap I would really appreciate it?
Question #2
CAP #61 The +side will connect to pin 8 of the 6X5 and the - connects to power transformer lead(center tap)at resistor #60.
Cap#20 The + side connects at the junction of resistors #21 and 22 - connects to chassis ground.
Cap #20a The + side connects to pin 3 of the #41 tube - connects to chassis ground.
Good Luck
Now I think I've got it!
Part #20 and 20A are effectively 2 separate 8 mf capacitors in the same cardboard tube with a common negative lead. I'd mount the new caps where they were originally (see below) and connect both 8 mf negative wires together. (NOT the negative from the 18 mf.) You might need to run a new negative wire from where you join the two 8 mf negatives together because the wires on your new caps might not be long enough.
I almost always restuff electrolytics, even the cardboard ones. For the two-wire ones, I put two new caps inside the cardboard tube and solder the negative wires together. I use heat-shrink sleeves to prevent the positive wires from touching each other. Then I bring the wires from the new caps out through the holes in the rivets (or sometimes I need to drill a small hole in the rivet or beside it). Then I solder the new wires to the old ones as close as possible to the rivet. You usually have to pay attention to which new capacitor + wire connects to which color old + wire, but since yours are both 8 mf, it doesn't matter.
I draw diagrams or take pictures before I take the old capacitors out so I can connect the wires back just as they were.
The two electrolytics (or three, if you don't restuff) should be mounted against the front of the chassis near the candohm multiple-tap resistor (in the upper left of your picture), instead of hanging where they do in your picture. There are a couple of slots in the chassis where Philco ran a thin strip of sheet steel to clamp the electrolytics to the side of the chassis. On one of my 42-355s the thin strip was missing, so I used a plastic tie-wrap instead.
John Honeycutt
By the way, I need some of those spring do-dads in your first photo, so if you find out where to get them, please post. One of my 42-355s is missing one of them, and the other is missing all of them. I think their function is to press the felt pad that goes on the back side of the push buttons tightly against the buttons so the light from the pilot bulb doesn't shine out from around the buttons.
John Honeycutt
Anyone on here have some of these Springs out of a junker they are willing to part with.....???
There are currently 1844 online users. [Complete List]
» 2 Member(s) | 1842 Guest(s)
