47-1227 - Radio will not tune in any stations.
Threads: 3
City: Middletown, PA
State, Province, Country: Pa
I have a Philco model 47-1227. It has been completely restored. All capacitors and resistors have been replaced. The audio works. We get sound from the record player but unable to tune in any stations. Have minis 2.5 volts at osc. tube. osc. tube does not change voltage when tuning dial is changed. No am or fm. Any ideal what's wrong? HELP!!!!!!!!?!
(This post was last modified: 06-09-2019, 06:53 PM by Lucky.)
Threads: 268
Time to break out the signal generator and inject a modulated 455kc signal @ test point A. This is w/the set set up to receive an AM signal and see what you get from the spkr.
Threads: 3
Receive nothing from test point A or when connected to antenna
Threads: 268
Ok inject a 455kc signal @ pin 1 of the 6ba6 and see what you get from the spkr.
Threads: 3
We get nothing from pin 1
Threads: 268
How about pin 6 on the 7R7.
Threads: 3
Pin 6 works with. Get loud tone
Threads: 3
06-09-2019, 08:38 PM
Pin 6 works. Hey loud tone.
(This post was last modified: 06-09-2019, 08:39 PM by Lucky.)
Threads: 268
Ok so you have a problem around the 6BA6. Check the pin voltages according t o the service info. Also be sure the heater is lit.
(This post was last modified: 06-09-2019, 08:46 PM by Radioroslyn.)
Threads: 3
pin 1. -.26 volts
pin 2. 0 volts
pin 3. 0 volts
pin 4. 0 volts
pin 5. 280 volts
pin 6. -1.14 volts
pin 7. .06 volts
Heater is lit
(This post was last modified: 06-09-2019, 09:09 PM by Lucky.)
Threads: 43
City: Brownsville 42210
State, Province, Country: Kentucky
filament should be pin 3 & 4 and pin 6 should be 100v
(This post was last modified: 06-09-2019, 09:48 PM by jake wells.
Edit Reason: error
Threads: 3
pin 3 grounded at center of tube
pin 4 shows 6.6 volts ac
The tube is lit and working
Threads: 43
pin 6 should not be reading -1.14 it should be 100V check the resistors and capacitors in that circuit.
Threads: 3
Will check Tomorrow night.
Threads: 43
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM |
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM |
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM |
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM |
Thank you.
I went to your online library and found 2 schematics.
I will download and compare to components!Ken D. — 06:31 PM |
It is a 16B tombstone.morzh — 06:13 PM |
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining.
The PSU...EdHolland — 06:06 PM |
Hi Everyone,
New member but have been reading this for awhile for tips!
Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM |
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM |
Hi DConant
Yes, you can replace chokes with resistors. You do stand the risk of increased hum. the solution is to inc...MrFixr55 — 04:23 PM |
