06-13-2019, 09:32 PM
Will a model 84(part# 5266) transformer work in a model 52 (part #32-7180) thanks,carl
Model 84 transformer- model 52 transformer
06-13-2019, 10:53 PM
No wrong heater voltage.
When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
06-14-2019, 09:58 AM
I also suspect it is a smaller transformer.
Any substitutes you can suggest???? Thanks carl
06-14-2019, 10:22 AM
Is this a USA model 52 or a Canadian model 52? Big difference.
-- Ron Ramirez Ferdinand IN
06-14-2019, 10:47 AM
Yeah...about 4 pounds of difference
06-14-2019, 12:14 PM
No, no, Mike.
The USA model 52 is a 1932 model and was available in table model, cathedral and console versions (plus a low production, undocumented grandfather clock version). The Canadian 52AF is a 1942 model and was only available in console form. To further confuse things, Philco Canada also produced a 52-A in 1932, apparently only as a lowboy console, with basically the same chassis as the USA model 52. -- Ron Ramirez Ferdinand IN
06-14-2019, 01:09 PM
Them Canadians.
But was the 1932 radio 25Hz...oops....cycles per cecond? People who do not drink, do not smoke, do not eat red meat will one day feel really stupid lying there and dying from nothing.
06-14-2019, 01:45 PM
The 52-A models were. A model designated simply "52" (not 52-A) would have been designed for 60 cycles. There were some Philcos produced in Canada which were made for 60 cycle AC, but 25 cycle AC sets seem to have been the majority for Canadian-built Philcos prior to WWII.
And starting in 1939, Philco of Canada completely revamped their model numbering scheme, so some late prewar as well as postwar models sometimes reused model numbers of prewar USA Philcos, causing great confusion today. -- Ron Ramirez Ferdinand IN
06-14-2019, 03:06 PM
ron,it is an American model, from the Hartford ct area.are there any under chassis photos available.i will forward a photo of mine. thanks,carl
06-14-2019, 04:55 PM
The issue you have is that you need a transformer that has a 2.5v filament winding to power most of the tubes on this chassis. By late '32 and onward manufactures were using up their older 2.5v tube and started in on using the new 6.3v tubes. These were more compatible with auto applications and other battery powered uses.
The transformers w/a 2.5v winding are still available but are some what limited and expensive. Some folks will retube the chassis w/6v tubes and use a 6v transformer but on your set there isn't a simple replacement for the 47 tube. It would require a socket change to a 6 pin socket and a 42 tube. When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
06-14-2019, 06:12 PM
As for substitutes, if you can obtain a known good one, a power transformer from a model 50 or 51 will work as a substitute.
The problem here is that these power transformers, having been mounted under the chassis, were subject to higher temperatures in an enclosed space and therefore have a higher failure rate. -- Ron Ramirez Ferdinand IN
06-14-2019, 10:39 PM
Will a 20 xfmr do? It drives as many 2.5V tubes.
Don't know about the B+. People who do not drink, do not smoke, do not eat red meat will one day feel really stupid lying there and dying from nothing.
06-15-2019, 10:35 AM
Electrically I think it would but physically my best recollection is that it's taller and narrower so don't know if it could fit under the chassis.
It's abt 5 1/2 tall x 3 3/4" wide. When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
06-15-2019, 11:55 AM
What is a 20 xfmr???
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
