Tube from SG
How do you test a 0A3 Tube.. Its not listed for my Hickok 600A
Skip
The 0A3 is a cold cathode voltage regulating tube. It operates a bit like a neon bulb, and will glow when in operation. You can check if it is working by measuring the voltage between pins 2 and 5 while it is in operation. The voltage shouyld be about 75 volts.
Here is a link to the data sheet: https://frank.pocnet.net/sheets/049/0/0A3.pdf
It is same as Zener for solid state.
There are currently 2718 online users. [Complete List]
» 1 Member(s) | 2717 Guest(s)
