08-07-2019, 05:00 PM
Hi guys -
Picked up a clean 53-658 a few weeks and started on it yesterday. It's all original and clean under the chassis.
http://www.nostalgiaair.org/Resources/do...013774.pdf
It does not power up on AC and does not register any volts on my amp meter. Tubes test good. Am I correct that the likely culprit is the selenium rectifier? I haven't replaced one of these yet and could use some guidance.
This article suggest installing a terminal strip with 1N4004 diode and resistor between 20 and 200 ohms. Outside of starting with a 100 ohm resistor and repeatedly measuring, is there a known resistor value I should use?
http://www.w3hwj.com/index_files/RBSelenium2.pdf
