Philco 37-61
Hello,
My Philco 37-61 came to me without the AC/Tone switch. It basically was wired to come on when plugged in. I think I have found a substitute switch but need help in how to wire it up. The AC part is obvious, but the tone part is clear as mud to me. Does someone have a nice hires picture of the original switch in place or a sketch of how it's wired up? Also, what is the general opinion of my replacement switch...doable? Good substitution for lack of the original?
dos0711 Wrote:...what is the general opinion of my replacement switch...doable? Good substitution for lack of the original?
That depends on what you have as a replacement. How many poles? Positions?
Remember, the tone control circuit is separate from the AC switching circuit, even though both functions are handled by the same switch. They are electrically insulated from one another.
Sorry...thought I had posted a link to it...here are some pictures...yes, the ac is a separate switch...
[Image: http://i.ebayimg.com/22/!Bb(uf6!BGk~$(KG...!~~_12.JPG]
[Image: http://i.ebayimg.com/23/!Bb(vWg!!mk~$(KG...Q~~_12.JPG]
Okay, very good. How many positions does this replacement switch have? Do you have the specifications of this switch, and if so, can you show these here, please? This will help a great deal in determining if it will work. It appears that it will, but the specifications will tell for certain.
It didn't give a lot of info...
Quote:CRL Rotary Switch 2 CKT 3 POS / on off switch NOS USA
He advertised it as being used in a lot of older 40s and 50s radios...
Here is where I'm getting it from...
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...0365456281
That looks like it would be a very good substitute. Now we have to find out how those lugs connect in the switch?
Hmmm...maybe I'll order a few and check them out. Those would make good substitutes in 1937 Philcos that only have a "high" and "low" tone position. They might even substitute for Philco 19 and 89 off-on-band switches.
Just made an offer on five of them; we'll see if he accepts. If so, I'll pin them out for you when they arrive.
Thanks Ron! That would certainly help me out a bunch! I was hoping they would work and help someone in the same boat that I'm in!
The seller accepted my offer on five switches and I just paid for them; so when they arrive, I'll be back with more details. Icon_smile
Ron Ramirez Wrote:I'll be back with more details. Icon_smile
Please do!
The seller accepted my offer also, bought five. They are going fast, looks like he has sold twenty already.
M R Radios   C M Tubes
Any update Ron?
Sorry, my switches arrived two days ago but I've been very busy with my custom-built 97 project which is now complete.
Here is a back view of the switch, showing the contacts and description of each:
[Image: http://i326.photobucket.com/albums/k420/...rminal.jpg]
Now, a schematic of the same switch:
[Image: http://i326.photobucket.com/albums/k420/...switch.jpg]
When the switch is in the "off" or first (1) position, nothing is making any contact. When turned clockwise to the second position, the AC switch makes contact, and the two wipers connect to each of the terminals labeled "2." Finally, when the switch is rotated one more position to the right to the third position, the two wipers now connect to each of the terminals labeled "3." The AC switch remains "on" in positions 2 and 3.
For use as a tone control in Philco models such as the 37-61, only one of the wiper terminals is used, along with the corresponding "2" and "3" contacts. In other words, use the "2" and "3" contacts that are next to the wiper terminal being used. The wiper is connected to ground, nothing to terminal 2, and the proper ends of condensers (40) and (41) are both connected to terminal 3.
This switch should also make an excellent replacement for the off-on-band switch in models 19 and 89 as well as some versions of models 14 and 91.
Note: These switches are supplied without mounting nuts. (At least, my five switches do not have any mounting nuts with them.) However, proper nuts and lockwashers for these should not be difficult to find.
Thanks a million Ron! You couldn't have explained it better!
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
There are currently 545 online users. [Complete List]
» 1 Member(s) | 544 Guest(s)
