Field Coil resistance for Model 95 Philco Loboy
As noted I am trying to find out the field coil resistance, since the schematic I'm using does not show this info. Appreciate any info on this.
If you have the "G" speaker which went into the 95s the field coil should be around 3200 ohms. See the speaker info at: https://philcoradio.com/library/index.ph.../speakers/
Thank you Klondike 98 for the info, much appreciated.
There are currently 2198 online users. [Complete List]
» 2 Member(s) | 2196 Guest(s)
