Philco 200X
I have a 200X that the top is missing the center section of veneer. Anyone have a pic or know what the grain orientation is for this section?
Could it perhaps be like my 201X, only without the inlay?
[Image: https://i.imgur.com/n5IWYhD.jpg]
Not so much the 200X has no inlay on the top nor is the edge routed. The inlay is on the edges.
Here you go!
Source: https://www.radiomuseum.org/r/philco_200x.html
Tnx Much!
Though it would face front to back but wasn't sure.
Was your 201X top difficult to remove? I got two 200X cabinets one the top is missing all the veneer and is warped the other is just missing the center section veneer. I'm thinking I'm going to switch the tops, one cabinet has a 201 chassis and sticker (Kirk's frankenradio).
The top on the 201X was pretty easy to remove. I just took our all of the screws that went into the top and gently tapped it around the perimeter from the inside of the cabinet with a rubber mallet.
The top had clearly also been glued down (in addition to the screws) but the glue had weakened to the point that the top came off pretty easily. There were 10 or so screws holding down the top so I didn't bother regluing it.
Phactory Phrankenradio...!
Icon_smile
My Philco 37-116 Restore
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
There are currently 373 online users. [Complete List]
» 2 Member(s) | 371 Guest(s)
