38-62 noise
Set has been recapped and out of tolerance resistors replaced but produces a light static with the volume all the way down. The set plays fine and picks up many stations i have been poking around with a chop stick to looks for intermittent resistors that is the only thing i know to do. All tubes test good / strong.
I did replace the resistors with metal oxide / film resistors instead of carbon.
Merry Christmas. Happy Hanuka.
Jake did you clean the inside of the volume pot? DeOxit works miracles on potentiometers. That may correct it.
Gregg Icon_thumbup
Might try some WD-40 in and around the tube sockets and clean the tube pins .
I have run into some mica caps that do what you describe and there is one on the plate lead of the 6Q7 tube, item #27 250pf, you could try that. Also the fact that you hear it with the volume control all the way down says it is beyond that point or in the power supply. Also any original resistor can cause that static sound.
Greg
Already taken the volume control apart and cleaned it with deoxit along with the tube pins that helped some. I will look into the mica's that are in the set along with the factory resistors.
No#27" 250pf tied to the plate of the detector tube is there suppose to be voltage leakage to ground noticed 14 volts on the ground side of the capacitor.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2240 online users. [Complete List]
» 3 Member(s) | 2237 Guest(s)
