Threads: 270
Actually something a little more simplistic would be to remove the XXL tube wrap some wire around the glass part like 3turns. Hook the the unsheilded lead from your generator to one end of the wire you just wrapped around the tube. The other end of the wire around the tube just leave loose (unconnected). Reinstall the XXL tube connect the other lead from the generator to the chassis. With this setup with all is working you should be able tune the generator to the frequency on the radio's dial. Can't align the trimmer for the rf stages with this setup.
If you are not to receive any stations check your voltages @ the XXL tube and the 7B5 tube.
Now I think I've got it!
(This post was last modified: 12-15-2019, 09:41 PM by Radioroslyn.)
Threads: 54
City: Shenandoah,
Hi Derek, in post #10 you state that you did finally get a signal through and aligned the IF strip but still no stations received. You should check and see if your oscillator is working. You can "listen" for it on a working radio by first tuning your Philco to 1000KC and tune a second working radio to 1455KC. Tune the Philco up and down a bit and you should hear a reaction in the second set if it is close by. If not, possibly your oscillator isn't working!
Ron
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 3
City: Salisbury
State, Province, Country: NC
This question may sound silly. How do you check the voltage at a tube? Plate, screen and bias
Threads: 291
City: Wilsonville
State, Province, Country: OR
One way is to use a socket adapter that provides some contacts on the topside of the chassis for you to connect your voltmeter leads to. Sometimes these show up on ebay. This image was cut from a page on the RadiolaGuy.com page who also may have some available for sale.
[Image: https://www.dropbox.com/s/vg5i66avthljpj....jpg?raw=1]
The other is to turn the chassis on its side so you can get at the bottom of the tube sockets to connect the voltmeter lead to the proper pin. Of course this involves accessing the chassis while its powered up so you need to be extremely careful. I usually make the voltmeter connections first then power the set up.
Threads: 3
City: Salisbury
What voltages should I see
Threads: 3
City: Salisbury
I am getting only. 5 or so volts
Threads: 3
City: Salisbury
Well I checked the wires coming from the transformer and found 2 that were loose. I resoldered the connections and now I one very faint station on the low end of the dial! Lots of static.
Threads: 3
City: Salisbury
Threads: 270
Let's start here http://jollinger.com/radio/tubes/tube_basing.html
Study the octal/loctal base note the pin location vs the key. This is how you count the pins on these tubes. What we are looking for is voltage on pin 3 of the XXL. Should see some hv there. On the 7B5 we are looking for hv on pins 2 and 3. Pin 6 we should see some - voltage, a few volts.
Threads: 3
City: Salisbury
Ok if read these right there is no pin on number 3 for the xxl. On the 7b5 pin 2 -1.48 and on pin 3 there is 27.8 and on pin 6 there is -23
Threads: 270
Sorry on the XXL I should have said pin 2.
On the 7B5 pin 2 is low should be abt 27vdc. I'd have a look at #18 choke should read abt 20 ohms. If it's open or close to it that could cause the voltage drop from 27 down to 1.4v.
The voltage on the control grid is kinda high too I'd look at #13. If it's gone high it resistance that could be the cause.
Threads: 3
City: Salisbury
Voltage on pin 2 of xxl is148.7 and as far as the choke there are 27.8 volts before it goes through to the pin where it drops off to 1.16. I will check resistor 13 later.
Threads: 3
City: Salisbury
What watt are the resisters in this radio
Threads: 270
Turn the set off and measure the resistance across the choke.
Threads: 3
City: Salisbury
There is no reading through the choke
