Should one add a three-prong power cord?
So when restoring a transformer radio, is it a good idea or bad idea to add a three prong power cord and tie ground to the chassis?
I vote yes. You can lose the "Death capacitor" which can afflict appropriate pain if it fails. On the other side (the dark side,) you can lose all protection if somebody uses one of the adaptors to defeat the grounding, or if the wall outlet is wired incorrectly. I would add a fuse as well for good measure. Transformer or not, results can be shocking!
It's not a bad idea, as long as your wiring is correct and up to code. Of course the cord will not look authentic, but if you're looking to have an easy ground for your transformer-operated radio, this would do the trick (again, assuming your house wiring is up to code).
Do not add a three wire grounded AC cord to a transformerless(AC-DC) set. Even if the B- is floating (not connected directly to the chassis), don't do it.
Here is some cloth covered three conductor wire which might help with the look.
http://www.sundialwire.com/3-conductor-1.aspx
Jim
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
There are currently 545 online users. [Complete List]
» 1 Member(s) | 544 Guest(s)
